RE: GAS OUTBOARD guys this is our new home
Thanks F1 Madness-I'm sure I'll have many questions for you all. All the best with your build! I am up to sealing the interior of mine-I am a little concerned that I have not got the bottom sheet flat enough on the center section- there is a 0.5-1mm gap betwwen the sheet and one of the bulkheads causing a bit of a ripple. Do you think this will be a problem? Is sanding and filling the answer or do I have to somehow remove sheet and start over? As it is not a race boat and this sheeting is out of the water when the boat is running, should I not get to worried about this?
Cheers,
Dion
