Please identify this engine
This was given to me. It's been crashed pretty hard and needs the crank straightened slightly. Missing a few fins here and there. Prop hub is BADLY bent.
It says 2.6 on the rear cover plate.
Any idea what it is? The rotating timing device is phenolic plastic and it has a ball on it for mechanical advance. No carb. Any idea where I can get one. The side of the cylinder where the carb attatches has 2 alignment pins. The carb would need too have two holes in the base to fit. This has a hole in the carb mount base for the pressure to the carb.
