RE: inverted 4 stroke
The problem that happens is that people fail to make sure the tank is centered about the needle valve.
If the tank is high the engine floods and in an inverted situation the tank is rarely low but if it is low, the fuel runs back into the tank.
Either way with the engine/tank relationship not correct, there is hard starting.
With a pumped OS four stroke engine the tank position doesn't matter.
