RCU Forums - View Single Post - inverted 4 stroke
Old 12-20-2010 | 10:26 AM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: inverted 4 stroke
I have found there is also a problem using them if not well broken in.  This is not just when it will run out a tank of fuel with a good idle, but when it has a good seal even when cold.  If not the fuel and oil will collect in the glow plug and make starting difficult.  Even when started the lower compression can cause more issues when inverted.
