G75
If your engine runs well, I.e: has a good idle, top-end, and transition, then you really don't have a problem. That's all the manufacturer was worried about when the engine was designed. The carb really wasn't intended to be used as a shutdown device.
Usually, though, if an engine will not shut down when the throttle is closed, a carburetor air leak should be suspected. A leak at the front bearing would make itself evident by the fact that a lot of raw fuel is spraying out when the engine's running at high throttle levels. If you don't have the fuel spraying out, then the seal at the front of the engine's good.
On model 2-stroke engines, the front bearing almost always has nothing to do with the seal. The "seals" you see are just basically dirt shields to help deflect dirt particles away from the balls and ball races. The actual seal is made by a film of oil that forms between the crankshaft and crankcase forward of the carburetor. If the fit becomes too loose, then fuel winds up spraying from the front bearing. So that excess fuel doesn't build up there, a groove in the top of the crank tunnel allows the excess to be sucked back into the engine when the intake valve opens.
Again, the usual reason an engine won't quit when the throttle is closed is a loose fit between the carburetor body and the throttle rotor. Over time, this can wear, especially if it was on the loose side when the engine was new.
