ORIGINAL: BaldEagel
Also consider the JetMunt Merlin 90 the Merlin is 90mm wide, I have one in a Sprint and its an excellent internal start Kero turbine, service from Gaspar is exemplorary, but its a small but, but a but it is, the EGC and sensor cables are permenatly attached to the turbine, this prevents any quick change to another airframe you may wish to do, I do not know if the Rabbit and Wren are the same, perhaps gooseF22 will confirm.
Mike
Wren still has the EGT probe and RPM sensor on a long cord for the small motors, however standard servo extensions can be used. the Larger motors are plug and play types with the Ethernet plug for the sensors... dont know on Jet C..stuff..
IF you were to want to swap frequently, add extensions, or mount ecu closer to turbine... that would go for any turbine with permanent wires. have done both..
So...Larry, confused enough?... welcome to turbines... The point is to pick something you will enjoy.. remember its a hobby.. have fun and fly.!! see you out there... Its alot of fun to get a gang of turbine guys together and fly, cuss, yell, talk crap, and fly some more and each other thinks they have the best stuff... "definition of a hobby".
