RCU Forums - View Single Post - prop advice needed
Old 08-04-2003 | 03:14 AM
BotleRocketWar
Default prop advice needed
Try an APC 11.5x4...That ought to do the trick pretty good. Will really add to the braking effect. It's a wider blade, with less pitch...You might want to try a 12x4 and a 12.25x3.75 as well and see which one you like the most.
