RE: (( MODS on POLARIS-LIBERTY 800 VES )) TEXX
there is 4 screws on the bottom side.. 2 in the back toward the beggining of the track.. then there is 2 inside just infront of the metal suspension plate. you can put mod 380 motors in it but you will most likely have to make your own gear box. some people use a belt and pulley system. then you can go brushless no problem. then you can make a mount for a 540 or 550 motor depending on what you want to do. keep us posted
