RCU Forums - View Single Post - P70SE or P100
Old 12-23-2010 | 05:07 PM
Kenrico's Avatar
Kenrico
Default RE: P70SE or P100
ORIGINAL: Modellbau USA
The P100 case diameter is the same as the P70 but it is a little smaller in length and it also weighs less. The turbine will have a few extra lb. more than the P70.
sounds good! do you have any numbers on the Thrust lb? is it going to be more than the P80SE?
