ORIGINAL: Kenrico
sounds good! do you have any numbers on the Thrust lb? is it going to be more than the P80SE?
[/quote]
That shouldn't be too hard to figure out. The naming convention most turbine manufacturers use when introducing an engine is indicative of its thrust in newtons. So I would expect a P-100 to be rated at 100 newtons, or 22 pounds.
