ORIGINAL: joeflyer
ORIGINAL: Kenrico
sounds good! do you have any numbers on the Thrust lb? is it going to be more than the P80SE?
That shouldn't be too hard to figure out. The naming convention most turbine manufacturers use when introducing an engine is indicative of its thrust in newtons. So I would expect a P-100 to be rated at 100 newtons, or 22 pounds.
[/quote]
I was thinking that also, but then we have the P80 in the 22LBS so would they discontinue the P80se also? hmm another mystery[sm=72_72.gif]
