RCU Forums - View Single Post - P70SE or P100
Old 12-23-2010 | 08:41 PM
Kenrico's Avatar
Kenrico
Default RE: P70SE or P100
ORIGINAL: Gary Jefferson
I guess by logic the P-100 should fall somewhere between the P-80 @ 22 lbs and the P-120 @ 28.5 lbs.
Kenrico, since you just started flying turbines I doubt you remember, but the P-80 was a 17lb thrust turbine at one time. Jetcat made improvements and the P80 went to 18lbs, then 19lbs, and up to 22lbs where it is at now. The great thing is that the P-80 has remained just as reliable as it has always been even though the power has increased by five pounds over the years.
I would imagine the P-60 will be around for a long time because of the segment of the market it fits. I have owned several P-60's over the years and they little jewels. One of my favorite turbines.
Gary, thanks! for the history of the P80, you are correct I didn't know that, i was assuming the difference between the p80 and p80se was just throttle response. I must agree with you a 100% on the P60se being a little jewel. after the experience i had with an other brand turbine for the last 3 months and now owning a P60se i must say JetCat is my favorite and will have my business as far as i can, this p60se was 100% plug n play. I flew it the first time on Sunday and got 6 flights, didn't get anymore because of windy conditions. but it is a total trouble free Turbine not one adjustment needed. I Totally recommend a P60se for beginners.
