ORIGINAL: Gary Jefferson
I guess by logic the P-100 should fall somewhere between the P-80 @ 22 lbs and the P-120 @ 28.5 lbs.
Kenrico, since you just started flying turbines I doubt you remember, but the P-80 was a 17lb thrust turbine at one time. Jetcat made improvements and the P80 went to 18lbs, then 19lbs, and up to 22lbs where it is at now. The great thing is that the P-80 has remained just as reliable as it has always been even though the power has increased by five pounds over the years.
I would imagine the P-60 will be around for a long time because of the segment of the market it fits. I have owned several P-60's over the years and they little jewels. One of my favorite turbines.
Gary, i went over n read you post again, now i have another question. if you say or assume by logic the p100 would drop in between 22 and 28lbs, and the p70 is being discontinued what is going to fill in 17lbs gap?? If it is true that the p70 is going to be discontinued, and the p100 is the same size as the p70 like Henry said, would you guys agree with me that the p100 would be somewhat a 2 in 1 Turbine? what i mean by 2 in 1 is that we would have say a 25lbs turbine the same size as a 17lbs turbine, in other words we would have a turbine that can be put in a bigger jet for its thrust but can also be used in smaller trainer jets because of its small size and being able to limit it down to 17lbs.
hope i explained myself clear enough for you guys[sm=confused.gif]
