RE: F27 Stryker Part 9: Crazy DARK SIDE - Beginners to Dark Extremes
TWIN STRYKER BUILD:
When I left off on Page 17, I had installed the servos.
Hinging the elevons with a 3M Mailing and Storage Tape hinge works well. I'm confident in its security for this lite build. Haven't proven it yet on a super heavy, but I know the tape hinge is bullet proof when done right.
The servo wires had to be routed under and around the carbon tube frame. To tunnel under a carbon spar, I use an Allen key heated up to bore under the rod. The wires then poke up right at the edge of the electronics bay where they can be neatly tucked away.
The hot wire loop in the soldering gun again makes quick and neat work of cutting a hole for the AR500 receiver.
