RCU Forums - View Single Post - valves:mechanical vs electronic
Thread
12-25-2010 | 05:42 PM
13
rbxbear44
My Feedback: (
86
Jan 2005
1,692
Talking Rock, GA
RE: valves:mechanical vs electronic
[quote]ORIGINAL: tucson
Quote:
ORIGINAL: rbxbear44
Quote:
ORIGINAL: tucson
sounds like they are binding up. Have you lubed them and made sure you had good movement without the brakes on, while spinning the wheels?
No Have not lubed them. I will check that out.
Stan
Don't know which planes you have but the the heavier ones...I re-lube and check about every 10-15 flights. Kingcat was good for about 30 flights before needing to be done.
I use UP-6 valves exclusively and they work proportionally very well. Mechanical all the way!!!
Best of luck,
Rex
Reply
Like
rbxbear44
View Public Profile
Send a private message to rbxbear44
Find More Posts by rbxbear44
View iTrader Profile
