RCU Forums - View Single Post - Timing Issue
Thread: Timing Issue
Old 12-26-2010 | 11:59 PM
bcchi
Default RE: Timing Issue
ORIGINAL: tkg
The XL ignition needs 24-26 degrees BTDC on a 3W. Using the stock XL sensor in the 3W holes gives you around 5 degrees BDTC . If you have a one magnet motor. With a two magnet motor the timing can be correct or 5Deg BTDC depending on which magnet your triggering off.
Hello TKG,
Are you still in HI.
No snow here got to fly the DL 20 on Fri & Sat,Yes on Christmas day
BC Still buildings for 3-W
BCCHI
