RCU Forums - View Single Post - Lower Crankcase shape.
Old 12-27-2010 | 08:46 AM
pe reivers
Default RE: Lower Crankcase shape.
edit:
Had not seen your reply Greg. So this answer is directed at Hobsy.
There IS a difference.
The load on a propeller at idle is practically NIL. During transition, the engine has no time to heat up. It uses the spare fuel in the crankcase plus what the carb supplies to overcome the fuel shortage during acceleration.
Low end torque is with the engine loaded at full throttle without rpm change (i.e. by a large prop). Not all engines are alike when treated like that.
Torque and power graphs are drawn with full throttle operation results, the engine gradually slowed down by adding brake power, or gradually accelerating by driving a spinning mass. Transition data do not enter that picture. There should be no throttle management during those tests.
Edit:
The latter dyno test is a bit like accelerating a car, albeit without the added air resistance that a car, or in general a vehicle, would impose on an engine. These dyno tests normally start their readings, when transition from idle to full throttle operation is finished. Data accumulated during the transition however also can be very valuable.
For instance, I saw MVVS dyno tests, done to record spool-up with different air entry bells on the carb. Also interesting to see was that with throttle closing, a very slight power rise could be observed as the valve traveled from fully open to partly closed. So the walbro should not be completely open if one seeks best power!
