RCU Forums - View Single Post - Good prop for OS FS91SII
Old 12-27-2010 | 07:31 PM
jester_s1
Moderator
Default RE: Good prop for OS FS91SII
You'll break a MAS if you hit the ground with it too. If the 3D thrust is good enough with the 14 inch prop, then just go up in pitch a bit. A 6 pitch is a good all around aerobatics prop, although you will lose some of the vertical grunt with it.
