RCU Forums - View Single Post - Good prop for OS FS91SII
Old 12-27-2010 | 07:49 PM
ameyam
Default RE: Good prop for OS FS91SII
Actually, I already hit the ground a couple of times with the MAS on Sunday. I realised you need to keep a bit more power on the 4C engine as its idle is so low there is no thrust at all at idle. So when the airplane stalled a couple of feet off the ground, I gave both power and elevator but hard landed regardless a couple of times. Then in the last landing of the day I kept a couple of clicks of power and touched down so softly I couldnt have kept it down softer myself by hand. Regardless, the MAS is quite OK even after the ground strike, an APC in its place would have broken
I am putting in an ordred for 2.75" PUF wheels and a 15x6MAS and 14x6APC at my LHS, will test this weekend if possible
Ameyam
