ORIGINAL: MinnFlyer
Ok, I was just curious.
If you have it working, but one servo is slow, I would suspect the servo. The 10CAG has no option to slow down a servo that I am aware of.
I've finally figured it out on the flap programming on the 10cag. I missed to NULL ch #7 in the Aux-ch. Another problem that I was encountering was the lagging in one of the servo. This was caused by the RX battery (NiMh) that required charging. Problem solved.
Digital servo draw more current. It wasn't the servo as I had switched servos to pin point the problem.
