RCU Forums - View Single Post - How many cc's for 16lbs at 6100' elev for 3D TR's?
Old 12-28-2010 | 04:05 PM
wingspan99's Avatar
wingspan99
Default RE: How many cc's for 16lbs at 6100' elev for 3D TR's?
Yes, I got that at Jefco, for $80 I couldn't pass it up, with that 96" wing. It will back at Jefco this year if you want it! I'm planning on a 6' diameter disc like a Rountuit for the DLE-55. 2" thick foam is soooo easy to work with. The more I look at it, the more I realize I could move the wing to the bottom by cutting a wing opening in the bottom, and avoid having to do anything else to it except close up the top and reposition the servo tray. It would look waaay better and probably fly truer for pattern. Then I need a canister muffler for the DLE-55 because the box muffler that came with it is LOUD. Know any good canister setups? Can I make one up, like a mousse can muffler?
