RE: Robbe Type XXI And The Cats Meow
Just installed wireless telemitry system,it monitors many peramiters that I have selected.Motor temp of the right side,amps,acumulated mam ,voltage ,pack voltage and when to return to base,ESC temp,prop RPMs and depth in mms the sub dives or surfaces all in real time and set with limit alarms so that I know whats upor if I have gone too deep for a shallow pond lets say.The Electrical peramiters are all read by one single sensor, a ring hall effect one that when placed at the main leads powerfrom the Lipo pack shows a host of operating peramiters,even if weeds get tangled up in the prop the amps draw goes up the set alarm will alert me that there is a problem and to bring her in or an electrical event.Even the servos glitches and possitions are minitored live as needed along with how much power there using!
The reciever like unit with all of the wires connected to it is the recorder,it is light and has all of the required markings on it so that you wont have to worry about hooking up the wrong thing,just like a reciever it all installs in minutes the temp sensor just slides in under the motor and the one for the ESC is in the cooling fins,the RPM mini magnets are the hardest to install with CA no biggie its done in minutes the sensor is a magnetic induction type,set for prop head speed the softwear even has the gear ratio adjustable by the user,totally user freindly and fun to use.
A water sensor also alarms ,high temp and Lipo cut of warning alarms are also programed in a few easy steps,the screen with the gauges is the stock picture the une I use was set by me becuse I like digital readouts beter there more acurate and easy to understand,but one can set what ever one likes,all can be seen live at the pond with a laptop or in front attached to the radios mast but in didgital form only.
later I might find a mini computer to display it like on the Laptop but at the TX.
This is cool stuff to the max and has been around for sometime with the fliers and I have been loving it for some time now as well !great range and works underwater.
Dave Amur Sub Yard
go to eagletreesystems.com
