RCU Forums - View Single Post - Firewall attached to Fiberglass
Old 12-29-2010 | 10:53 AM
Gray Beard
My Feedback: (-1)
Default RE: Firewall attached to Fiberglass
I can never keep this straight, sorry. There are two types of epoxy/resins used to make up a glass fuse, they don't stick to each other very well. There is often a releasing agent film left behind from the mold too so your fuse must be cleaned real well or even if you have the correct resin it doesn't stick well.
Because I have never been able to keep the two straight in my head I started using gorilla glue for a lot of my glass repair. Reinforcing behind the fire wall is a very good idea. Do some testing on your fuse to make sure what you use will stick correctly.
