RE: WHY IS RCU SCREWED UP?????????
Also can't ping your site so... L3 has shut down ICMP packet responses. Either in LA at a switch or at your ISP... If that some terror avoidance thing to a DDOS attack it's foolish. Can't ping your own site to see if it's still up? 'Brilliant'. Can't traceroute past this bridge/switch.... INTERNET-BR.car1.LosAngeles1.Level3.net
Make a call get the network guys on a bridge line and get them to fix it. You have enough traffic hitting your site to have them diagnose either a bad board, port or otherwise, maybe even mis-matched half/full/speed issue in the switch. It only takes 1 small error that's not looked at to get problems to crop up. And if you don't ask all the questions you get the same response.... silence.
Got this to after trying to post.
We are sorry...
You are seeing this message because of one of the following reasons:
Your session timed out.
The server was restarted before you made a HTTP POST (posting a message, registering an account, login, etc.)
Problem #1:
You probably spent too much time and your session timed out. This is, however, rarely the cause of the problem because we implemented a session keep-alive mechanism to prevent this issue from happening. However, the server itself could have experienced some problems that prevented this mechanism to work as it should, and therefore we cannot completely rule out the possibility of this either.
You need to make sure your browser has cookies enabled. See below for instructions:
Netscape Communicator 4+:
Select "Edit" from the browser Menu bar
Select "Preferences"
Double click on "Advanced"
Verify that "Accept only cookies that get sent back to the originating server" is selected
Select the "OK" button
Microsoft Internet Explorer 4+:
Select "View" from the browser Menu bar
Select "Internet Options"
Select "Security" tab
Select "Custom (for expert users)" security level and select the "Settings" button
Locate "Cookies" and verify that "Allow per-session cookies (not stored)" is enabled
Select the "OK" button on the "Security" window
Select the "OK" button on the "Internet Options" window
If you already have cookies enabled and still experienced the problem, see problem #2 below for other possible causes.
Problem #2:
Your server experienced problems and was forced to restart. Restarting a server will erase all session data and our protective mechansim had no choice but to drop your HTTP POST because we had no way to identify you without valid session data.
Many forum administrators host their forums on shared servers, on which could have more than 200 sites hosted together. Sometimes the server has to be restarted because some badly written programs on other sites may drain the CPU/RAM and cause the IIS to restart itself. This is unfortunately an inevitable situation that many site administrators and its users have to face from time to time.
Technical Information
For more information, please contact forum admin.
