ORIGINAL: stevebeale
Harry
i can confirm that there is a small issue with the end point on my futaba 14mz and ff9.. also in PCM there is no + movement on chan 5.(on FF9)
Can you confirm that with the tx and Wea set to their normal 100% defaults, the Wea stops responding to the stick movement towards the end of stick travel, i.e. there is a deadband before you get to full stick movement. Or does your Futaba not encounter the problem until you turn the tx travels way up? A UK user is telling me his Futaba at normal 100% has the same deadband as my Multiplex.
http://www.rcmf.co.uk/4um/index.php/...87654.html#new
i have also had a problem with one of my TX units not booting, on power up (none of the leds come on at all)
, it has done this several times. i switch of and on and on it comes, as anyone seen this if so is a bug or a majour problem
Wow, I get that quite a lot, perhaps 1 in 15 times I switch on, it's like no power has got to the aerial box. I assumed mine alone had a problem but it looks like we might be uncovering another intrinsic Weatronic fault.
Harry
