RCU Forums - View Single Post - slight engine problem
Old 12-30-2010 | 06:49 AM
1QwkSport2.5r's Avatar
1QwkSport2.5r
Default RE: slight engine problem
ORIGINAL: rcpowerhorse
havent posted on here for a while but i have an engine problem
it is a .28 sh engine and it runs nicely through 1 tank and then it wont start on the second. the glow plug has been changed and the needles have been reset to factory standards.
can anyone think of what to do??
When you try to restart, hold the throttle open some. If it starts, your low speed mix is too rich. Check the plug for wetness. Also might want to check compression after the engine is hot. Since the liner expands at temp, it could be losing compression when warm. Worn out pistons create a nitemare to restart a warm engine. My SH .28 P6 restarts like a dream.
