RE: DA 150 question
In India the temps are not that cold. In fact the temp that I operate in is rather a nice warm 25-28C. Now, the engine always fires with the choke closed and throttle at full stick. Then I open the choke and throttle at idle, the engine will fire and run for about 5 seconds and quit. I also tried the throttle at 50% and flick the prop. Now the engine will start and a higher rpm and the rpm ocillates pretty rapidly.. as if I am playing with the throttle from idle to mid. The engine does go to full power, but then after a bit it will quit. Seems like there is dirt in the carb. I will check it tommorrow.<div>
</div><div>thanks.</div>
