ORIGINAL: mrcoolpop
I'll try it on tomorrow and see what happens, and thanks for responding.
When you see the fuel reaching the carb
DON'T STOP
Continue turning the prop
x2 more revolutions.
Then remove your finger over the carb (..used it to prime it )
Turn the prop
x2 more revolution to be sure your engine won't hydrolock..
Then install the glowplug driver and use your starter.
Throttle must be set at
1/4 of the movement,
5mm open!
Been there...done that...my
O.S. 65LA never let me down !
