RCU Forums - View Single Post - The 1/6th Tanks Are Comming
Thread
12-30-2010 | 03:20 PM
10
pzrwest
Aug 2007
1,439
Cardiff, ON, CANADA
RE: The 1/6th Tanks Are Comming
Update:
Well I filled an old plastic pill bottle that was the right diameter for the muzzel brake and long enough with urethane resin and let it cure over night. I then drilled a hole down the center of the cylander of resin, inserted a bolt and locked it with a jam nut, then chucked it in my drill(poor man's lathe) then turned the outer shape of the muzzel brake. When satisfied with the shape I then drilled out the bore diameter and then cross drilled the vent holes. Here are pics of the muzzel brake snug fitted to the end of the barrel......Harold
Reply
Like
pzrwest
View Public Profile
Send a private message to pzrwest
Find More Posts by pzrwest
View iTrader Profile
