RCU Forums - View Single Post - Best Way to Attach a Canopy
Old 08-04-2003 | 07:52 PM
Topgun2mo's Avatar
Topgun2mo
My Feedback: (45)
Default Monocote
On monocoted aircraft, I have used monocote itself to attach the canopy. Use just enough heat to get the monocote to stick to the canopy. I usually use strips around 5/16" wide. Check out my gallery and look at the Skybolt. It uses the monocote method. I have been through crashed and the canopy is retained. Some simple slicing with a razor blade and you can remove the canopy.
JMO
