RE: SIG LT-40 Need Help
Enjoy the build its a great kit and a great first plane, I still have mine a year on and still fly it.
Btw if this is your first plane there is no reason to fit dual servo to this plane as one servo is plenty good for the job, with the big wing andsmall ailerons this planewill always have big slowrolls.Some of the more experience fliers are prob fitting two servos so they can experiment/play with different set ups but this could end up causing problems for a newb. Im not saying dont do it as this hobby is about having fun and experimenting but you will still have a great flying plane built standard.
Also I have pancaked my lt40 in a few times and although the wire landing gear is soft and requires bending back now and again it is a great shock absorber for poorlanding skills, dont make your new gear to strong or it could be the fuse that gets damaged and not the gear.
One thing I wish I had done when building this plane is provide fixing points for floats in the fuse for even more fun.
As I said great plane. Nice and strong for begginer abuse
