RE: A different approach
You probably can save some weight by not sheeting the fuse all the way to the tail, to avoid secifically the "tail weight". Some weight can be saved also if the turtle back is constructed by some lighter/thinner wood or foam.
There is a 2m wood pattern construction article on AMA a while back. It is for gas power but should give some idea on how to save weight.
