RE: FK SBA 60 Speeda - Build
Main gear struts flat spots ground, struts aligned, gear installed, plumbed and gear drop tested.
The air lines bypass the wheel wells inside the wing and come out in front of the retract unit. I ran the lines beside the retract unit and made 180 bend in the line to connect them to the retract unit. Makes a clean installation.
To be continued…
