RCU Forums - View Single Post - Are All Rcxl CDI units the same?
Old 01-01-2011 | 08:51 PM
  #46
bcchi
Default RE: Are All Rcxl CDI units the same?
Look at no#4 with a timing light and tell me you see.I need some one else to check this and tell me I haven' lost it.I have sent parts to Ralph so he can check this.
BCCHI
[quote]ORIGINAL: mpascual
RCEXL ignition manufactured for DLE engines are now labeled wit a number:
#1 is the first model intended for the DL50-DLE55 and side induction DLE30, #2 is the twin version for the 100-111, #3 is for the DLE30 V2 modified at same time than read induction, #4 for the DLE20 ....
I've seen the standard (model A01) ignition 'curve' , but i suspect the #2 and #3 models have a different static advance than #1. Maybe the rpms when advance is lowered is at hi rpm in #3 and #4 .
Regards
[/quote
