RE: ALPHA 40 HELP! Electronics
Sounds like you may have a connector problem. Try using another batt. if you have one, not to check the batt, but to check the connector. If not, check your connector pins on your present batt. Try binding without any servos plugged in. It's a proccess of elimination.
Tom
