RCU Forums - View Single Post - Anyone working on a harrier?
Old 12-18-2002 | 12:30 AM
wsmalley
Default Math Lesson!
If your turbine produces 40 lbs thrust after losing 40%, you've got one powerful engine! Care to share any of the details of the engine construction? Off the shelf turbine wheel-or home spun? What's the diameter of the engine? Are you going to have the valving to the rudder, wing tips etc., bleed off of what you;ve already built or do you have another trick up your sleeve?
