RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 01-03-2011 | 03:08 PM
  #2502
foxworth's Avatar
foxworth
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
While I was running mine I noticed a lot of air bubbles going into the carb. It seemed to take more time than normal to pump the fuel out of the tank,like it was pulling in air some where. I pulled the tank, the supply side did not have a good seal. I built up a spot on tube with solder and clamped the flexible tube on each side of the spot.( inside the tank also) I just ran it again and it seems to be fine. The holidays and weather have put a crimp in the flying.
Our weather has been on the cool side for us,I will give it more time to warm up. Here two or three days below 50 is a real cold wave.
