RE: When to replace the bearings
If you run good fuel, tune it correctly, and keep the motor clean it will have a lot less problems. I raced the same engine on 50+ percent nitro for two years with out any need to replace parts. With that said, if the bearing feels rough or if you have a unexpected hard landing (some call it a crash) then the rear bearing can be damaged and should be replaced.
Skids
