Anyone working on a harrier?
Pegasus
When you say twin spool, does that mean you have
the Fan/power turbine behind the core turbine ?
Did you run the 32,000 rpm shaft through the
center of the core turbine or below it.
Man that is cool.
Remember to get it to fly you need 3 lbs of thrust
on each axis.
I would like use your design to build a turbofan
and install it in a plane. It would have ~30 lbs of thrust
and burn a lot less fuel !!
Eddie Weeks
