RE: Forgot to use After Run
I've never used any and I've never had any problems with engines rusting up. But that's probably because I make sure to run them out of gas when I'm done. Or pinch the line and run them dry that way. I would be more concerned with whether the crash itself damaged the engine than I would if it was gummed up or something. If it spins freely and has good compression it should run just fine.
