ORIGINAL: ********nut
jwayne,
I would like to add something here too. Along with everything that has been mentioned; does your transmitter allow for adding any expo to your control surfaces? If it does; add some expo to your rudder. That will help some with the inadvertant rudder use. With expo; if you move the stick a small amount; the rudder will move a very small amount if any depending on how much expo you program into the transmitter. Might help you.
hahaha you beat me to it. i was hoping to be the one suggesting that one. definitely helped me tremendously while learning.
