RE: New Decathlons From Seagull 91 and 120 Size!
I actually will use the tailwheel. It is not foam like on the 72" Yak I got last year. No flat spots. I will change the tiny allthread to a 2mm shoulder bolt and use some brass bushings. The bushing through the spring aluminum arm is loose and needs fiddling as well.
