RCU Forums - View Single Post - ? about flex shaft
Old 01-06-2011 | 06:20 PM
Nick3
Default ? about flex shaft
This my first boat, the aluminum outer shaft has a little bend in it causing excess heat build up causing the inner (plastic like inside tube) to melt and seize up the flex shaft. Is the aluminum part suppose to be straight? Remember this is my first boat so this is all new.
