RCU Forums - View Single Post - 8fg Smoke Pump Programing
Old 01-06-2011 | 08:19 PM
bbrown2828
My Feedback: (76)
Default 8fg Smoke Pump Programing
ok i am trying to set up my smoke pump on my 8fg I am trying to do a programable mix so when a switch is on the smoke pump will enage when the throttle is at a certian position
so the only problem i am having is no matter which way I set up my three Postion switch all the way up is allways off and then the middle is on and even if i set the bottom to off if i switch it to the bottom it still engages the pump at a low speed what could be causeing this any help will help here this is my first smoke set up
