Firewall Help....
Im putting together a VQ .42 Hawker Hurricane. I went to put the fuel tank in and found the pre-drilled hole in the firewall was drilled off set. (see pic) would it be ok if i cut the hole larger or could I risk messing up where engine mounts? The yellow hole is around where the fuel tank sits.
