RCU Forums - View Single Post - Firewall Help....
Old 01-07-2011 | 01:31 AM
Kostas1's Avatar
Kostas1
Default RE: Firewall Help....
As long as you don't have a problem with that missing wood part of the firewall,
to put the engine mount template over the firewall & mark the area for the x4 holes that keep the mount in place
there is no problem installing your fuel tank as you should,
even if the fuel lines make a Z-bend/travel to rich your carb/needle valve!
