RCU Forums - View Single Post - astro hog tail wheel
Old 01-07-2011 | 05:54 AM
wattmeter's Avatar
wattmeter
Default RE: astro hog tail wheel
ORIGINAL: DaveB
Wattmeter,
I don't know whether you are converting a Hog with triangle gear to a tail dragger or if you are building a kit. Having said that, if you are converting from tri to tail dragger, probably the easiest way is to mount a new landing gear (Dubro and others have them) on the fuse and a Sullivan tail wheel bracket aft.
If building a kit, the previous post by ''thatsakitbuilt'' is the way to go. Keep in mind, with a tail dragger, the gear is 1'' longer in length.
DaveB
DAVEb
I have already built the kit with a tri-gear and I'm wanting to change to a tail dragger and having trouble on how to put the tail wheel on, not sure how to go about it.
Thanks to all for the help.
wattmeter
