RCU Forums - View Single Post - MK "Magic" Plans...
Old 01-07-2011 | 01:09 PM
  #106
bem
Default RE: MK
Hendrik du Preez,</p>
I have now fixed a digital version of the R&ouml;gamodell "plan" of Magic 40. It is same plan for R&ouml;gamodell 60 version since on my plan there is a sticker placed over the specification, on the sticker (for Magic 40) it is Wingspan (Spw, Spannweite) 1440 mm, Total fuselage length (Rul, Rumpf uber alles l&auml;ngde) 1310 mm, Flying weight (Flgw, Fliegt gewicht) 2900-3400 gram, Wingloading (Flbel, Fl&auml;chenbelastung) 58-68 gram/dm2 AND under the sticker I can read for Magic 60: Wingspan 1660 mm, Total fuselage length 1450 mm, Flying weight 4100 gram, Wingloading 65-70 gram/dm2. All measurements on the plan is for Magic 40 but can be figured out what they should be for a Magic 60.
I also fixed digital version of the building instruction for Magic 40 (in German language).
R&ouml;gaModell Magic 40 building instruction (in German) below.
R&ouml;gamodell Magic 40 plan (not as detalied asMK or RCM &amp; E plan of Magic 60) below.
Note: The drawing itself is scale 1:1 but the actualmodel drawn on this scale1:1 paper has not any special scale, it has some measurements here and there, it is not meant to scratchbuild from this plan. I think You should use RCM &amp; E or MK Magic plans instead.
/Bo</p>
File Type: pdf
File Type: pdf
