RE: Sig Wonder Build
Concrete/asphalt is the plan,as that is what is at the field I plan on Flying from,,plus I didn`t want to risk engine damage by scraping or busting the prop.
The closer I get to a finished Fuselage,,the more I`ll know,,I have already purchased the servos,two 311 Hitecs and also one micro,that I "Was" thinking of using for the nose gear steering,,now I might switch the micro role to the throttle,since it shouldn`t require much torque if I build it right.
As of now(Last Night) the Fuselage is almost done,bottom sheeted and waiting to be trimmed and sanded,wing is near done only the center sheeting and dowels (Beefed up the Balsa mounts for them thanks to reading this build) and will probably start the Horizontal Stab/Elevator tonight (if feeling better.home from work today).
Thanks for the tips
Rt4957
