RCU Forums - View Single Post - New Decathlons From Seagull 91 and 120 Size!
Old 01-07-2011 | 02:16 PM
  #226
aramsdell
Default RE: New Decathlons From Seagull 91 and 120 Size!
Eclipse3g[/b], Look on the bottom of your wing panel, in-line with the wing-tube and 277mm out from the inner end of the wing. You will most likely find a tiny hole in the covering. That is the pilot-hole for drilling through the wing-tube and top side of wing. I foolishly pushed a piece of wire up through it. I am going to cover the tiny hole on top and maybe add another thumbscrew inside up near the wing tube or some other way to assure a real secure install.
alan
